Hi All,
So i need some help and guidance, we have recently started using M2M sim cards in the FMC130 devices, and would like to monitor the performance of the SIMs, maybe through historical log reports. This is to understand how well the M2M sims work compared to normal SIM cards of the same network carrier.
Hello @romankili
I believe this data will be available from your network provider platform.
From the device side you can check from the network types with AVL ID 237 to know the network status
You can also check the AVL ID 21 for the GSM signal
Please check this wiki page for more information: Mobile Signal Strength Recommendations - Wiki Knowledge Base | Teltonika GPS
Best Regards
Maynard C
Thanks Maynard.
This is fine. However, i am more after historical data.
