Leds blinking continuously & Active hours
Is it possible to switch off the LEDs when no cable is connected. Now they are blinking continuously.
And can you also set hours when the charging station is active or inactive
It’s possible to add a scheduler for the charging station:
Regular - when to charge:
Peak hours - when charging is forbidden
There is no possibility to turn off LED’s completely.
LED sleep mode: After 10 minutes of inactivity LEDS will start to blink less frequently at lowest brightness
Br,
