I have some FMB devices (FMB110, FMB120, FMB920). When vehicle on stop
, sometimes send data where changes coordinates, speed, io movement is 1, data send type is 1.
Here are the configuration:
Good day, Thank you for contacting Teltonika Telematics!
As per the configuration settings, I can see STATIC NAVIGATION mode is disabled. Kindly enable it as it will filter out the GPS coordinate when device is not moving/stop.
Please refer link below your reference.
Ashutosh S.
