Subject: Missing JSON Codec in Teltonika FMB920 Data Protocol Settings
Hello Everyone,
I am currently following the tutorial provided by Teltonika to set up my FMB920 device with AWS IoT Core FMB920 Getting Started with AWS IoT Core - Wiki Knowledge Base | Teltonika GPS . According to the tutorial, I need to select the “Codec JSON” option under the Data Protocol section. However, I am unable to find this option in my device settings.
Here are the relevant screenshots of my current configuration:
Expected Data Protocol Options:
My Device Configuration:
As you can see, my device only shows options for “Codec 8” and “Codec 8 Extended.” I have uploaded the necessary certificates and followed all the steps in the tutorial up to this point.
My questions are:
Why is the JSON codec option not appearing in my device’s Data Protocol settings?
Is there a firmware update or additional configuration required to enable this option?
Has anyone else encountered and resolved this issue?
Any help or guidance would be greatly appreciated!
