I would like to report an issue I am facing with the Immobilizer feature on the FMM130 device, and I hope you can assist us in resolving this matter.
Currently, upon ignition, I have observed that the DOUT output associated with the Immobilizer activates immediately. However, my application requires a specific configuration that is not met by the default settings. I would like to configure the device as follows:
- Ignition Start: Upon ignition start, the DOUT output should not activate immediately.
- Parameterized Time: After setting the ignition to high, the activation of the DOUT output should only occur after a parameterized time in seconds.
- User Identification: If, within the parameterized time, I identify myself using the iButton/RFID card, the DOUT output should not activate.
I would also like to highlight that in our company, we have previously used a device with a similar function, and we found this feature to be very beneficial for our operational context.
The FMM130 is a commendable device, and with a few adjustments, like the one mentioned, it could become even more tailored to meet the specific needs of our application. I appreciate your attention and cooperation in resolving this issue. If necessary, I am available to provide more information or participate in any troubleshooting process that may be required.
