IO operand "Monitoring" vs "On Delta change"
hi,
i am reading the explanations of the various Operand options but i cannot get answer to my question:
I need an Input value (for example: fuel level) to be included in all messages (Monitoring) and also to generate event On Delta Change with high value = 30.
can it be done?
Hi @Rafi,
Good day! Unfortunately, you may only select one Operand setting for the event occurrence either Monitoring whereas in all records you would receive the data parameter, or On Delta Change with the value that you were selecting.
Suggesting you do the functionality on the server end, if you require an event when the Fuel level value changes ±30.
I hope this helps.
Patrick
