Inquiry: Fleet & Tool Tracking Solution for 20 Vehicles in Bermuda
We are a small fleet operator with approximately 20 vehicles and are looking for a combined fleet management and tool tracking solution. Our main requirements are:
  • GPS vehicle tracking (real-time location, history, basic alerts)
  • Tool/asset tracking (being able to see which tools are on which vehicle)
  • Web-based portal to view vehicle and tool locations and run basic reports
I have a few questions:
  1. Coverage in Bermuda
    • Does your system (devices + SIM/connectivity platform) work reliably in Bermuda?
    • Do you have any recommended SIM or connectivity options for this region?
  2. Recommended hardware
    • Which GPS tracking device do you recommend for our vehicles (OBD, wired, or other) for a fleet of this size?
    • Which tool/asset tracking tags (e.g., BLE/RFID or similar) do you recommend for tracking tools stored in the vehicles?
    • Can the GPS tracker in the vehicle detect and associate the nearby tool tags, so we can see which tools are currently loaded on each vehicle?
  3. Trial / test devices
    • How can we obtain one vehicle tracking device and one tool/asset tag (or a small starter kit) to test with?
    • What is the approximate cost for the hardware and any monthly service fees for a pilot?
Thank you for your interest in Teltonika Telematics solutions for your fleet!
I have found 3 operators there
Operator 2G (GSM) 3G (UMTS) 4G (LTE) 5G
Digicel 1900 MHz Band 5 (850 MHz) Band 13, Band 17 (700 MHz) Not deployed
One Communications 1900 MHz Band 5 (850 MHz) Band 5 (850 MHz), Band 12, Band 13, Band 17 (700 MHz) Deployed 2023 (bands TBD)
Paradise Mobile N/A N/A 700 MHz, 1700 MHz N77 (3700 MHz)
Compatibility Results
FMC920-QJIB0 (EU/EMEA version):
  • :white_check_mark: 2G: Will work on Band 2 (1900 MHz GSM)
  • :cross_mark: 4G: NO compatible LTE bands - missing Band 5, 12, 13, and 17
  • Result: Device will fall back to 2G only with very slow data speeds (max 85.6 Kbps)
FMC920-QKIB0 (Americas version):
  • :warning: 4G: Partial compatibility - has Band 5 (850 MHz) only
  • Result: Will get 4G on One Communications’ Band 5 network, but will miss Band 12/13/17 coverage. Will fall back to 2G in areas without Band 5 coverage.
Recommendation
Consider these alternatives:
  1. FMM00A or FMM13A - North America versions with BG95-M1 modem (designed for North American bands)
  2. FMM80A - Also designed for North America
more information about mentioned devices:
  1. FMM00A FMM00A - Teltonika Telematics Wiki
  2. FMM13A FMM13A - Teltonika Telematics Wiki
  3. FMM80A FMM80A - Teltonika Telematics Wiki
  4. FTM880 FTM880 - Teltonika Telematics Wiki
  5. There are more devices for North America:
Category Model Technology
OBD FMM00A CAT M1 (BG95-M1)
FAST & EASY FTM880 CAT M1 (BG95-M1)
FAST & EASY FTM887 CAT M1 (BG95-M1)
FAST & EASY FMM80A CAT M1 (Quectel)
ADVANCED FMM13A CAT M1 (BG95-M1)
ADVANCED FTM134 CAT M1 (BG95-M1)
E-MOBILITY FTM305 CAT M1 (BG95-M1)
PROFESSIONAL FMM650 CAT M1 (BG95-M3)
FMM13A with BG95-M1 MODEM (for now lets say we stick with FMM13A)
This is the ideal device for your Bermuda fleet operation. Here’s the band compatibility breakdown:
Realistically, any North American market device will be fine
Perfect Band Match
What Bermuda Networks Need:
  • GSM 1900 MHz (Band 2) :white_check_mark:
  • LTE Band 5 (850 MHz) :white_check_mark:
  • LTE Band 12 (700 MHz) :white_check_mark:
  • LTE Band 13 (700 MHz) :white_check_mark:
  • LTE Band 17 (700 MHz) - covered by Band 12/13
What the FMM13A-BG95-M1 Supports:
  • GSM: 850/900/1800/1900 :white_check_mark:
  • LTE CAT M1: B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/B25/B27/B28/B66/B85 :white_check_mark:
  • LTE CAT NB2: B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/B25/B28/B66/B71/B85 :white_check_mark:
Coverage Analysis
One Communications: Full compatibility
  • Band 5 (850 MHz LTE) :white_check_mark:
  • Band 12 (700 MHz LTE) :white_check_mark:
  • Band 13 (700 MHz LTE) :white_check_mark:
  • GSM 1900 MHz fallback :white_check_mark:
Digicel: Full compatibility
Paradise Mobile: Partial compatibility
  • 700 MHz LTE :white_check_mark: (Bands 12/13)
  • Note: Paradise’s primary 5G network uses 3700 MHz (N77), which this device doesn’t support, but their 4G LTE will work fine
Regarding the recommendation of which SIM provider to use, I can not answer, all mentioned should be fine
  1. Recommended hardware
For a small fleet operation like yours, I recommend the FMM13A as an ideal starting point. This device offers the perfect balance between immediate functionality and future expandability, allowing you to grow your telematics capabilities as you discover what works best for your operation.
Why FMM13A for Your Fleet:
Scalable Architecture
The FMM13A is designed with expansion in mind, so you can start with basic GPS tracking and gradually add advanced features as your needs evolve—without replacing hardware.
Key Expansion Capabilities:
  • Driver Identification & Authorization
    Add 1-Wire iButton readers to identify and authorize drivers, enabling driver behavior monitoring, access control, and accountability.
  • Advanced Vehicle Data Access
    Integrate optional CAN adapters (LV-CAN200, ALL-CAN300, or CAN-CONTROL) to read critical vehicle data directly from the CAN bus, including:
    • Fuel level and consumption
    • Odometer readings
    • Engine RPM and temperature
    • VIN number
    • Diagnostic trouble codes (DTCs)
  • Flexible I/O Configuration
    Multiple digital inputs (DIN), digital outputs (DOUT), and analog inputs (AIN) allow you to connect:
    • Sensors: Fuel level sensors, temperature sensors, door sensors
    • Safety devices: Panic buttons, driver alert systems
    • Control systems: Buzzers, relays, immobilizers
    • Custom solutions: Virtually any analog or digital accessory
  • Tool Tracking Integration
    Built-in Bluetooth support enables seamless integration with EYE Beacons for tracking tools and assets loaded on each vehicle.
The Learning Advantage:
Starting with the FMM13A gives you time to understand your fleet’s specific needs before investing in additional accessories. As you identify which features deliver the most value—whether that’s fuel monitoring, driver behavior, or asset tracking—you can expand accordingly without hardware limitations.
This approach minimizes upfront costs while ensuring you’re never locked into a solution that can’t grow with your business.
  1. Trial/test devices
To get the units please be sure to contact the closest physical office. It would be Irving, Texas
To make it more simple just use the contact us button here: https://www.teltonika-gps.com/about-us/contacts
There you will be able to ask about prices, Support does not have any price lists
