Ignition source from CAN-adapter?
Hello, I have a FMM130, CAN-CONTROL IMMO and Fiat Ducato 250 (EURO 5 PLUS). Program number is 12677 and I connected them using the wiring diagram of FIAT_DUCATO_EURO5_PLUS_250_2014_en.pdf (2022-12-15). In order to properly set up the Immobilization-Feature, I need to provide an ignition source. In the wiring diagram it shows, that I need to connect the ignition source to DIN1, but tried to avoid this, by opting for the CAN-CONTROL with IMMO function! I did not expect that I’m still forced to do so many custom wiring work.
I noticed that CAN-CONTROL is already able to report this, but there is no option to use it as source for ignition detection:
Can you please elaborate on, why this is not possible and when you make it available?
By default we don’t have this option from our based firmware. because not all vehicle supports ignition status from the CAN bus.
If you need this feature, kindly check with your sales manager, this can be done via firmware development.
Best Regards
Maynard C
