📹 How to Retrieve Video Clips from DualCam Memory via FMC125 (Without Triggered Events)?
Hello community,
We’ve set up a Teltonika DualCam with its respective FMC125, and it’s working well with the GPS Server platform.
  • I can see that the images and short video clips are successfully delivered either on demand or when triggered by an event.
  • As far as I understand, the DualCam has at least 64GB of internal memory and it records continuously while the ignition is ON — this is how it was installed and configured.
My main question is:
:backhand_index_pointing_right:t3: Is it possible to remotely retrieve video clips that are already stored in the camera’s local memory, even if they were not recorded as part of a triggered event?
If yes:
  • Is there a specific command to request those clips?
  • Do we need to include a timestamp in the request?
  • Or is there a different process to fetch previously recorded footage from the device?
Thanks in advance for your help! :mexico: :video_camera:
The storage in DualCam is MicroSD cards (up to 64GB), so there is no internal memory.
To request information with specific timestamp you can use command camreqDualCam SMS commands - Teltonika Telematics Wiki
So you can specify the timestamp of interest and request it from the DualCam.
Hi, SmoothOperator,
Thank you once again for your kind support.
Based on your explanation and assuming my DualCam device is equipped with a 64 GB MicroSD card, which—if I understand correctly—can store up to 48 hours of video, I’d like to confirm the following:
  • If I want to retrieve a specific video segment from those previous 48 hours,
  • And I know the exact date and time of the event I’m interested in,
  • Can I use the camreq SMS command to request a clip of up to 30 seconds,
  • Provided that the footage still exists on the SD card?
Just want to make sure I’m interpreting this functionality correctly before running a test.
Thanks in advance for your help! :sweat_smile:
Hi, PAULO,
Based on the Wiki, it can store up to 40 hours of video with 64 GB, but in general, yes, you can request data with a specific timestamp
