As you mentioned that even after upgrading the firmware for the device to latest version, the Auto Scan didn’t work.
Here are few things we request you to check:-
What is the status for CAN File transfer on FOTA Web account.
Please check the version of firmware for CAN chip for this device.
Further, as we shared in the similar post earlier, please check complete guidelines for FMC150 AutoScan feature. Same can be found by searching for AutoScan for Teltonika FMC150 on any search engine.
Also, as we mentioned earlier, this device FMC150 comes with inbuilt CAN Adapter, and hence doesn’t need any external CAN adapter. There is no need to set the Baud rate etc. for this device.
If the issue still persists, we request you connect with is through Teltonika’s Partners Portal and post your complete query there.
Thank You
Sourav
