How to mount FMC130 for best green driving performance
We would like to know how to mount the FMC130 in heavy duty vehicles for best performance in green driving events (harsh acc, break cornering). We are using Accelerometer as source. Should we mount in certain direction and does it matter for auto calibration if the GNSS has a good signal? Also, should the FMC130 be firmly fixed so it can not move?
Hello there.
Thank you for your question.
FMC130 can be mounted under the plastic panel behind the front window, with the sticker / engraving direction to a window for the best GNSS signal. The direction does not impact accelerometer features/performance.
More about mounting recommendations - FMC130 First Start - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
For optimal accelerometer performance, mounting the FMC130 firmly is neccessary to prevent false green driving events.
I hope this helps.
Jonas K.
