How to import/add devices into FOTA WEB
I have a couple fmc920’s and a number of fmc130’s that i need to change configuration using FOTA WEB to utilise eco/green driving solution. We have our saved .cfg config file ready.
My question: is there any documentation to explain the process of importing devices into FOTA so that i can deploy my new configuration to 20+ devices? i have read through Getting Started - Wiki Knowledge Base | Teltonika GPS with little success.
Hello @Harrison,
Good day! Unfortunately, clients do not have access to adding devices to Fota Web as the Device IMEIs will be automatically added under your Fota Account if you have purchased directly from Teltonika.
Meanwhile, if you have purchased the devices from another company I recommend you to check with them so that these devices could be added to your Fota Account. Otherwise, you may coordinate with your Sales Manager and he will gladly assist you with your query.
If you don’t have any contact with our Sales managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it.
Patrick S.
