How to display data from FMB130
Hi, guys.
I have rent a FMB130 tracker. Everything works, I’m able to configure the unit, but I would like to display data from it. Is there a way, how to do that?
I tried the Open AI - but it lies and lies. Set a FTP username and password. Where is this setting in FMB130? Pardon, there is no such a setting.
So - is there a way how to get data to any free (FTP?) server? I do not have a public IP.
Many thanks for your answer.
Petr Filipi
The Czech Republic
In the Configurator, you can set the server address and port in GPRS > Server
The device will send data in one of Teltonika’s formats (default: Codec 8 Extended). You will need an account with a GPS platform to use the data. For example, one device can be connected for free to Ruhavik: Pricing | GPS-Trace
If you’re planning to develop some software based on the received data, you may want to consider using Gurtam’s Flespi service: flespi pricing: plans, restrictions, SLA (10 devices for free)
Flespi converts Teltonika’s binary data formats into something more developer-friendly, like JSON or XML
It’s also possible to configure your FMB130 to send the data to two servers simultaneously. For example, Flespi and Ruhavik.
Good luck.
Many thanks for your answer. I will try it.
