I am looking for detailed instructions on how to connect and configure 5 ultrasonic fuel sensors to a single FMC125 tracker using the RS485 interface.
Please note that the standard Wiki article for the UL202 sensor (available at https://wiki.teltonika-gps.com/view/UL202_Ultrasonic_Fuel_Sensor) does not answer this question, as it only covers the basic integration of a single sensor and does not explain how to handle multiple sensors on the same RS485 bus.
Specifically, I need guidance on the following points:
Physical Wiring / Daisy-Chaining: Are there specific recommendations for wiring 5 sensors in parallel (daisy-chain) on the FMC125’s RS485 A and B lines? Do I need to add a termination resistor ($120\ \Omega$) at the end of the chain?
Sensor Addressing: How should the Modbus / LLS network ID/address be configured on each of the 5 ultrasonic sensors to prevent collisions?
Teltonika Configurator Settings:
Which RS485 mode should be selected in the FMC125 configuration (e.g., LLS, Modbus, or TCP Binary)?
How do I map each of the 5 sensors to the corresponding I/O elements (such as LLS 1 to LLS 5 Fuel Level / Temperature) so that all 5 measurements are sent independently to the server?
Firmware Version: Is there a specific firmware version required to support up to 5 sensors on RS485 for this model?
Any step-by-step guide, wiring diagram, or configuration screenshot for this multi-sensor setup would be highly appreciated.
Thank you in advance for your help!
