How can i disable FMC920 saving data while server is offline
I don’t need to get old records, I only need to get current and last location
The device has internal flash memory, so if the gsm connection is interrupted, the data will still be saved in the internal memory.
You can use sms/gprs commands to delete records or format the SD card if you don’t want the device to send the old data.
Below are the commands
deleterecords
sdformat
Meanwhile if you want device sends current data first , then configure the sort by as ‘newest,’ so it will send new records before old ones
Regards
Maryam
