Gps feature fmb 140
I have a project request from my customer. They want to create a feature for monitoring their lamp towers using the FMB 140 GPS connected to a genset. They want the following features:
  1. Remote scheduling to turn on and off.
  2. Temperature detection feature.
  3. Connectivity with the genset’s CAN bus controller. The controller has both CAN high and low with the J1939 protocol. Can the FMB 140 connect to the CAN high and low with this protocol?
The controller used by the customer is the SmartGen HGM4100LT.
Regards
Good day,
  1. Remote scheduling to turn on and off. - Check if you can use DOUT to control the switching ON/OFF the genset , POC is a must
  2. Temperature detection feature.- is it temp detection of the genset? we need detailed information like the datasheet of the genset to have an idea of how to capture the genset temp.
  3. Connectivity with the genset’s CAN bus controller. The controller has both CAN high and low with the J1939 protocol. Can the FMB 140 connect to the CAN high and low with this protocol? - Yes FMB140 is using a customized protocol you can to use the auto-scan to check if the genset is compatible with FMB140.
In this project better to create a helpdesk ticket or contact your sales manager If you don’t have any contacts with our Sales managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it. Note: as a topic, please choose “Vehicle telematics”. Or you can send an e-mail with a description of your situation to us: Teltonika - IoT, Internet of Things
