Are there any GPRS commands available for GH5200 to activate beeper, vibration or LEDs ?
Hi @0xFF
Good day, there are no specific commands to trigger audio/visual indication. These are triggered by User Interface settings in configuration.
Workaround:
You could try setparam 14040:0/1 GPRS command. This is an indication that the device is connected to the server and only when connected to the server device can receive GPRS command.
Kindly test it in case it didn’t work, please create an HD ticket and add you requirements if the features that you need is not available in the base firmware then it should be done through CDP
Best Regards
Maynard C
Hi @Maynard,
Thanks for pointing out this interesting workaround.
I enabled permanent link in records settings.
I can send new settings from the server, but after the tracker receives a new command,
the LED is off for 10 minutes.
Only after 10 minutes does the LED start blinking.
Which is a bit strange…
