GH5200 and Codec 8 Extended (battery percent)
Hello everyone.
I’m writing a server software that receive in TCP frames localization data from GH5200 devices.
I’m using Codec 8 Extended protocol for now. It works well but there is a little problem regarding battery percentage.
This information seems not to be sent in each packet, so I couldn’t know battery level in realtime.
How could I configure GH5200 to send always battery percent?
Thanks in advance.
Mario.
You’re right — the GH5200 using Codec 8 Extended doesn’t always include the battery percentage in every packet by default. The device typically sends battery info as part of certain I/O elements, and it’s not included in every AVL record unless explicitly configured to do so.
Thank You so much. I found in configuration the right way to get all records with battery percentage.
Now I would like to build a coding structure in order to generate the correct signalization about following events:
  • Device is starting a trip (Vehicle departure)
  • Device is stopping a trip (Vehicle stop).
Is there a way to combine I/O events “Movement“ and/or “Instant Movement“ to correctly report to my system that device is really starting or stopping a trip without false flags?
Thanks in advance.
Hello @mdesortis,
I hope you are doing well. GH5200 has the Trip/Odometer Features that could record start/stop of Trips. More information can be found on this link: Template:FMB Trip/Odometer settings - Teltonika Telematics Wiki
Hope this helps.
Patrick S.
