Hello I have two GH 5200. I want to configure them using WIN 11. The new CTC does not work for this tracker.
in the forum I found a link to the wiki but it is not Working anymore:
https://wiki.teltonika-mobility.com/view/GH5200_Firmware_and_Configurator
Got any advices.
Or ist the GH 5200 to outdated? Then I will return it to amazon.
Is there a newer Verion of the GH 5200?
What can I do?
With this file for .net installer it worked:
Good Day,
Please make sure you are using the latest Configurator version. When you launch the Configurator, it may prompt you to install the required .NET Framework components for the Configurator environment.
I also recommend running the Configurator as an Administrator. Once the required .NET components are installed and the application is run with administrative privileges, the installation should complete successfully.
