FTM887-Q2AB0 vs FTM887-Q5AB0 in USA
FTM887-Q2AB0 says it’s FCC certificated for north america, but Q5/Q6 is not. Is there a reason for this given the Q5 has the same band overlap as the Q2?
4G LTE bands
FTM887- Q2AB0 BG95-M1:
LTE FDD (CAT M1 Only): B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/ B25/B26/B27/B28/B66/B85
FTM887-Q3AB0 BG95-M3:
LTE FDD (CAT M1): B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/B25/B26/B27/B28/B66/B85 LTE-TDD (CAT NB2): B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/B25/B28/B66/B71/B85
FTM887- Q5AB0 BG95-M6:
LTE FDD (CAT M1): B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B2/ B25/B26/B27/B28/B66/B85 LTE FDD (CAT NB2) B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/ B25/B28/B66/B71/B85
Good Day,
FCC certification is granted to a specific hardware variant and is not determined solely by the LTE bands supported by its modem.
Although the BG95-M6 used in the Q5 variant supports several of the same North American bands as the BG95-M1 used in the Q2 variant, each complete device variant must undergo the applicable regulatory testing and approval process. This includes the modem configuration, antenna performance, transmit power, RF emissions, hardware design and firmware behaviour.
At present, the FTM887-Q2AB0 with the BG95-M1 modem is the variant certified and intended for the North American market. The Q5/Q6 variants should not be considered FCC-certified based only on their supported band overlap.
The current certifications available for each FTM887 variant can be reviewed here:
FTM887 Certification & Approvals – Teltonika Telematics Wiki
For deployment in the United States or Canada, please use the approved North American Q2 variant unless certification for another hardware variant is officially listed.
Thanks, and best regards,
Imran S.
