Fota WEb offline configurator
Dear Team,
I am reaching out regarding an issue I am experiencing with the Offline FOTA Web Configurator. Currently, the configurator displays only four device categories and does not seem to be compatible with the FMC 130.
I am unsure if I have downloaded the correct version of the FOTA Web Configurator. To resolve this, I would appreciate it if someone could provide me with the correct URL for downloading the appropriate version of the FOTA Web Configurator.
Thank you for your assistance.
Sudesh.
You probably won’t get as good a response, if any, from this Teltonika Networks Commnity. Post your question in the Teltonika Telematics Community at Teltonika Telematics - Teltonika Community
Hello @Sudesh,
I hope you are doing well. Unfortunately, Fota Web Configurator were only available with the new FTC devices.
However, you may create your Configuration file through the FMC130 Configurator which you may access below and save it as a new Configuration File to be uploaded on Fota Web.
FMC130 Configurator: Teltonika Configurator versions - Wiki Knowledge Base | Teltonika GPS
I hope this helps.
Patrick
