For an unknown reason my FMB204 doesn't have the correct date and time
How to get it updated, please, preferably without unmounting?
I assume that due to wrong date the sentences are being refused and therefore the FM204 is sleeping.
Hello @Ulrich.S
The device firmware or configuration can be updated directly through the configurator when connected to the laptop via USB cable.
In this case, keep the device connected to the vehicle, use the laptop, configure or update it.
The second option is to over the air, means though fota web. If you have access to the fota web account, the device can be remotely updated.
Regards
Maryam
Hello.
I was wrong. Due to my server not working for a year, he didn’t accept data from the tracker, while … the tracker has worked properly and saved all the data into his memory.
So when the server began working properly, the first data was the oldest … thus I misinterpreted is was the time and date of the tracker when I wrote my topic.
It took some days until all the data until now (more than 300000 data sets) has been transmitted … and now the popup is showing the right date and time.
Regards
Ulrich.S
