FMT 100 TRACKER usage of BLE LE beacons
i have recently purchased some FMT100 trackers and am wanting to use ble beacons for driver id.
I have read the tutorial and everything available but am not being able to see the device on the tracker, the TAG works perfectly connecting to my android phone.
The goal is to allow only some MAC adresses connecting the tracker , there i have another question which is the format of the MAC adress to upload to the tracker itself.
Thank you very much in advance,
Ricardo
Hello @Rmap,
I hope you are doing well. Are you using Eye Beacons or a third-party BLE beacon?
You may try to check the advanced beacon mode if you wish to connect other BLE beacons from the device, kindly refer to this link if you need more information: FMT100 Beacon List - Wiki Knowledge Base | Teltonika GPS
I hope this helps.
Patrick S.
Hello Patrick,
i would like in advance to say thank you for your guidance, about the the issue itself i followed the tutorial on how to activate ble le and activating beacons however there isnt any change on the status tab, it was supposed to appear another menu " Beacon Info" but it doesnt show up.
The beacon is an universal one , runned some tests with my phone and everything works but the tracker doesnt even see it.
Is there any limitation on ble le determined by power mode settings or any new firmware for the device?
I will attach the log.
Device info
Device Name : FMT100
Device IMEI :
Firmware Version : 03.25.15 Rev:32
RTC Time : 10/31/2024 03:11:15 PM
Device Uptime : 01:52:23
Power Voltage : 12764
Battery Voltage : 4003
Internal Battery Status : Not charging 89%
Last Start Time : 10/31/2024 01:18:58 PM
Ext Storage (used/total) : 13/122 MB
GNSS Info
Gnss status
Fix Status : Fix
Module Status : ON
Fix Time : 00:00:15
GNSS Packets : 6180
Satellites
GPS : 11
Galileo : 5
GLONASS : 9
BeiDou : 0
Total Satellites : 25
Satellites In Use : 17
Location
Latitude : 41.634648
Longitude : -8.360436
Altitude : 110.5
Angle : 85.19
Speed : 0
HDOP : 0.53249997
PDOP : 0.765
GSM Info
GSM status
Modem status : Modem on
SIM State : SIM ready
Actual Operator Code : 26801
Signal Level : Good Signal
GPRS Status : GPRS activated
GPRS traffic
Sent Data : 5,50 MB
Received Data : 234,95 KB
Total Traffic : 5,73 MB
Records
Sent Records Count : 284
Last Record Send : 10/31/2024 03:11:01 PM
Last Server Response Time : 10/31/2024 03:11:02 PM
SMS count
Sent SMS : 0
Received SMS : 0
SMS Count : 0
Sockets
Type : AVL Data Sending
Socket : 15.184.246.16:8501(TCP)
I/O Info
Ignition : Ignition OFF
Movement : No movement
Data Mode : Unknown on stop
GSM Signal : Good Signal
Sleep Mode : No Sleep
GNSS Status : ON with fix
GNSS PDOP : 0.7
GNSS HDOP : 0.5
External Voltage : 12764 mV
Speed : 0 km/h
GSM Cell ID : 64574
GSM Area Code : 26
Battery Voltage : 4003 mV
Battery Current : 0 mA
Active GSM Operator : 26801
Trip Odometer : 0 m
Total Odometer : 299356838 m
Fuel Used GPS : 0 ml
Fuel Rate GPS : 0 l/h
Axix X : -50 mG
Axis Y : -156 mG
Axis Z : -11 mG
ICCID :
Eco score : 0
User ID : 0x0000000000000000
BLE Temp #1 : 0 °C
BLE Temp #2 : 0 °C
BLE Temp #3 : 0 °C
BLE Temp #4 : 0 °C
BLE Battery #1 : 0 %
BLE Battery #2 : 0 %
BLE Battery #3 : 0 %
BLE Battery #4 : 0 %
BLE Humidity #1 : 0 %RH
BLE Humidity #2 : 0 %RH
BLE Humidity #3 : 0 %RH
BLE Humidity #4 : 0 %RH
Battery Level % : 89 %
BT Status : Device connected, BTv3 Only
BLE LLS Temp 1 : 0 °C
BLE LLS Fuel 1 : 0
BLE LLS Batt 1 : 0 mV
BLE LLS Temp 2 : 0 °C
BLE LLS Fuel 2 : 0
BLE LLS Batt 2 : 0 mV
BLE LLS Temp 3 : 0 °C
BLE LLS Fuel 3 : 0
BLE LLS Batt 3 : 0 mV
BLE LLS Temp 4 : 0 °C
BLE LLS Fuel 4 : 0
BLE LLS Batt 4 : 0 mV
Instant Movement : 0
BLE Frequency #1 : 0
BLE Frequency #2 : 0
BLE Frequency #3 : 0
BLE Frequency #4 : 0
BLE Beacons : ����
ISO6709 Coordinates : +416346.2667-0083603.4667+000.110/
Thank you so much,
Ricardo
Hi Patrick, did you had the chance to look at this?
Thanks!
Ricardo
Hello Ricardo,
Thank you for your feedback. Normally, the device supports iBeacon or Eddystone protocols for the Beacon Info. Meanwhile, I recommend you update the device Firmware version to the latest one first which you may access on this link: https://wiki.teltonika-gps.com/view/Special:Redirect/file/FMB.Ver.03.29.00.Rev.18_and_configurator.zip
Once updated, kindly select Beacon Detection Mode to ALL first so that all beacons nearby would be identified by the device. On a side note, I recommend you to disconnect the Beacon on your Mobile Phone during your testing on the FMT100 device.
I hope this helps.
Patrick S.
