FMP key duplifcation
Is it possible for an FMP device to send the same AVL Property ID with the same value and the same timestamp twice in a single transmission? For example, code 25 for BLE Temperature.
Do you know if there is any configuration option that could potentially influence such behavior?
Thank you
Hello @iton
If the I/O for the BLE temperature is configured as high priority and you set high and low limits, the device will send two messages. One data packet will be based on periodic timing, while the other will be sent as an event. Both packets will include the value and timestamp.
Kindly check more details related to the I/o priority and event sending from link FMP100 I/O settings - Wiki Knowledge Base | Teltonika GPS
Regards
Maryam
