FMM920 MQTT AWS Core
Hello forum
I’ve setup the Fmm920 to deliver data to AWS core IOT.
My question is:
Server 1 is to deliver data using TCP data protocol Codec 8 Extended
Server 2 is to deliver data using MQTT data protocol Codec JSON (Duplicate)
This seems impossible (Have to choose either Codec 8 Extended or JSON), or is there a workaround
Hi Nanna,
on the Device we don’t have a direct way of separation between server 1 and 2 concerning the Data Protocol.
Through Configurator you can choose either Codec 8 Extended or Codec JSON.
However, a workaround would be to send the data to Server 1 first using Codec 8 Extended and then forward the data to server 2 after encapsuling as JSON data.
I hope this helps
Best Regards
