I’m setting up a FMM920 device.
I’ve implemented a server with the codec 8 protocol.
Everything works fine while using a non secure GPRS connection
Now, I’ve set up a TLS connection and the device’s behavior changed.
With a TLS connection, the device send its data to the server (and data in memory) the, it disconnects itself (sending STX/LF bytes before that). After 1/2 minutes, it connects again and send its new data.
Without TLS, it stays connected. Sending data every minute.
Is this behavior correct ?
How to avoid this disconnection?
Problem solved.
Certificates were OK.
Debugging with Wireshark I saw the final response sent to the Teltonika device (4 bytes for the number of frames) was sent over the wire in 2 or 3 TCP packets. I don’t know why as I was using a Java method to write Int.
Using an array of bytes instead to force the 4 bytes to be in the same packet resolved the problem.
