Thanks for the reply.
I already have Deep Sleep selected (as shown in the attached screenshot, also my network settings are attached), but I’m still seeing ~20–27 mA average current consumption.
Ultra Deep Sleep isn’t available in my firmware options, and the wiki/datasheet mentions <4 mA for Deep Sleep.
Did I miss a setting, or is this expected on Cat M1-only networks (Switzerland, no 2G fallback)?
Firmware is 03.01.00.Rev.14. Thanks!
As per the current consumption shared above, it appears that the device may not be entering completely into Deep Sleep mode.
We request you to please check and apply the following:
Set the time synchronization source to NTP only
Ensure all sleep entry conditions are met, including:
Ignition is OFF
No accelerometer movement
No BLE devices connected
No active peripherals keeping the device awake
Once these conditions are satisfied, please verify whether the device is successfully entering sleep mode and observe the current consumption again.
If the issue still persists after applying the above checks, we kindly request you to open a support ticket. We will then analyze the behavior in more detail and provide you with a relevant configuration to help achieve the expected current consumption.
