FMM003 OBD in error state
I’m using a FMM003 with the latest firmware FMB.Ver.03.29.00.Rev.358 with an Audi A6 4G C7 from 2017.
The VIN is retrieved via OBDII correctly.
I’m wondering about the log entries:
[OBD.OEM] OEM Diagnostics:
OBDII data: 0
VIN VEH: (manual:0), source: 0
Current state: 6 (Error state)
FSM error occured: xxxxxx Can’t be read
Request error occured: 0
DataInfo is present: 1
New DataInfo present: 0
Request retry timer: 0 s
Request retry count: xxxxxx Can’t be read
General error count: 0
[OBD.OEM] Vehicle data:
VER:4
DB source: 0 (0)
GenResult: 101
VIN: XXXXXX (src:1)
Description: audi;xxxxx
GenTime: 1684836403
What does the Current state: 6 (Error state) mean?
Hello @betonme,
Good day! It seems that you are browsing through the device logs. Are you experiencing any issues with the device’s OBD data?
Errors from the device logs might not be useful for you. If you have some clarifications regarding the device, you may directly post them here.
Patrick
