Good morning,
I am about to order the FMM 130 tracking device.
I want to track , the speedometer,fuel consumption,oil temperature ect…
Do i have to take the CAN accesoiries or the FMM 130 is enough ?
Cheers
Good morning,
Cheers
Since the FMM130 doesn’t have built-in CAN-data processor so device requires an additional CAN adapter to retrieve data from the vehicle’s ecu. The ability to receive data depends on the supported list ,
Please check the list from link https://wiki.teltonika-gps.com/images/4/45/ALLCAN300_list_2024_07_11_en.xlsx
If you are looking for device with integrated CAN data processor then check the device FMX150 FMC150 - 4G LTE Cat 1 Tracker With CAN Data Processor
Regards
Maryam
Thank you for your aswner,
So with only FMM 130 i can have
-Geo localication
-central doors locking
-Fuel gauge reading
But for all other sensor it will need the CAN adapter ?
Hope my question is not redundant
Cheers
Geo-Localization : Yes
Central Door Locking: With Dout (Digital Output)
Fuel Gauge Reading: Using Analog
About this point ;
Could you specify which sensor you would use with the device?
I mean CAN adapter is specifically to retrieve vehicle CAN bus data , If you need to connect any other sensor, such as fuel, temperature/humidity , or any sensor supported by Bluetooth, we can check the possibility of support .
Regards
Maryam
Well to retrieve the oil temperature , speedometer, odometer and fuel consumption
Cheers
And last question lol
What is the 1-WIRE connect to ?
Sorry for all these questions
For this information, you’ll need to use an additional CAN adapter.
The 1-Wire interface can be used for multiple purposes, including connecting with the iButton for driver authentication, 1-Wire temperature sensors, and 1-Wire RFID readers
Find the more info from below link
https://wiki.teltonika-gps.com/view/1-Wire_RFID_Reader
https://wiki.teltonika-gps.com/view/1-Wire_Temperature_Sensors
https://wiki.teltonika-gps.com/view/1-Wire_iButton_Reader
Regards
Maryam
