FMC920 Sleep Mode not waking on movement
I am trying to get my FMC920’s to enter Deep online Sleep.
I have been able to get them to go into sleep once power is disconnected but they will not wake again with movement and will only wake when power is reconnected. it shows as being asleep and movement is dectected in the io status but still no wake.
Attached is screenshots of the config and wondered if anyone could point me at the setting im getting wrong.
Hello
"I have been able to get them to go to sleep once the power is disconnected "
the condition to enter the sleep mode is ignition off, movement 0, and there shouldn’t be any task going on,
I suggest you configure the ignition to Din1 (yellow cable from the device), leave the device connected to the main power without Din1 until the device enters to sleep (there should be no movement),
to awaken the device again, try to connect the Din1 to the power, >> check if the device exists in sleep mode
Reference: FMC130 Sleep modes - Wiki Knowledge Base | Teltonika GPS
Let me know the test result
BR
laith
