Hello, I have FMC920 but I can not find custom scenarios menu on configurator. I tried to change firmware to 04.00.00 Rev:121, as it is says at Custom Scenarios - Teltonika Telematics Wiki , but nothing can found on configurator.
Hey,
Are you using the configurator that is downloaded with the firmware or are you using the base configurator? The custom scenarios tab will only appear in the configurator that is downloaded with the custom scenarios supported firmware.
Thanks.
This topic was automatically closed after 33 days. New replies are no longer allowed.
