My situation:
I’m experiencing an issue with my FMC920 (firmware 03.29.00 Rev21) located in South America. The device works correctly in general, but shows problematic behavior:
Problem:
GPS sends data normally to my server
When passing through areas without cellular coverage, it disconnects (expected behavior)
The issue: When returning to areas with good coverage (city center where other GPS devices work fine), it does NOT automatically reconnect
These disconnections can last for days until it finally reconnects on its own
Analysis from .dmp file via FOTA Web: The error that constantly appears is related to SIM card initialization:
[AT.RSP]
SIM card is not initialized yet
[AT.SEND]
ERROR @ m2m_at_cmd_api.c(298):CMD failed. Try:2
[AT.RSP]
SIM card is not inserted.
[MODEM]
Setting PWR state 1->0
[MODEM]
Changing Modem State from:1 to:2
[SCH]
Task eM2M_Tid_ModemInit[8] has been scheduled. Period: 5s
Additional details:
SIM card has not been physically removed
Device has internet access when working
GPS gets fix correctly (GPS Fix: 1, GPS state: 1)
Normal battery voltage (BatV: 4070, ExtV: 13654)
The issue seems to be specifically with modem/SIM reconnection
Has anyone experienced this behavior? Is there any specific configuration I should check to improve automatic reconnection after coverage loss?
Any suggestions would be greatly appreciated.
Thanks in advance.
