FMC650 Using Digital Outputs
Hi
We want to use the digital outputs controlled by gprs command setdigout are there any guides or examples available? including teltonika config, commands and wiring.
when using the command
setdigout 1111 60 60 60 60
to set all outputs high for 60 seconds only output one and three go high
Is there configuration needed before we can use the setdigout command?
How should the outputs be wired up? It looks like the voltage isn’t driven high when the output is high
Ryan
Good day, for controlling the DOUT using SMS/GPRS command please refer on this link: FMB setdigout - Teltonika Telematics Wiki
DOUT is an Open collector OUTPUT ( controlling external relays, LED, buzzers, etc.)
Reference: FMC650 General description - Teltonika Telematics Wiki
Check this document for the FMC650 wiring diagram : QM-FMC650.pdf
Best Regards
Maynard C
