FMC650 The message sending time to the server does not fall below 1 min and 20 sec
Hi
I am testing with the FMC650 device with the Teltonika SIM, I have the following configuration:
but on the server I am getting the data after 1 min, even though I have it configured to send data every second.
Can you help me with any recommendations or according to the configuration I shared with you, do you think there is something I am doing wrong?
I hope you can help me
thanks
Hi @ex_user
Good day, your device is configured to send records after the position is fixed, so the device will not generate any records if there is no position and time sync.
Please also check your server’s capability of receiving the records every 1 sec.
Please also try to test using the Flespi server. www.flespi.io
In case any issues are observed, please contact your sales or create an HD ticket.
Best Regards
Maynard C.
