We are using the FMC650 connected to the truck’s tachograph via the FMS connector (CAN bus).
We are currently developing a fleet management platform and we rely on tachograph data fields such as:
Driver 1 Activity (driving, rest, work, availability)
Driver 1 Cumulative Break Time
Driver 1 Driving Time (continuous, daily, weekly)
Driver 1 Last Daily Rest
The issue: We only receive these tachograph data fields when the vehicle’s ignition is ON. As soon as the ignition is turned OFF, the FMC650 stops sending any tachograph-related data.
However, the digital tachograph itself remains powered and the driver can still manually change their activity status (e.g., switch from driving to rest) even with the ignition off.
Our questions:
Is there a way to configure the FMC650 to continue reading tachograph data from the FMS/CAN bus when the ignition is OFF?
Does the tachograph continue to broadcast data on the K-Line or CAN bus when the vehicle’s ignition is OFF, or does the bus shut down entirely?
Is there any alternative wiring or configuration (e.g., permanent power on the CAN line) that would allow us to receive tachograph status changes in real time, even with the engine off?
Any guidance would be greatly appreciated. Thank you.
