FMC650 + Iridium
Dear Teltonika Team,
We are looking to test Iridium Edge’s satellite connections as backup from GSM Signal.
We looked into the wiki and documentation but did not have an answer for:
If FMC650 is configured for 10 second events when moving, and SBD is set to 60 minutes..is the device able to store the 10 sec events AND only send SBD every 60 minutes? Or does the Iridium activation when there’s no signal changes movement events to 60 minutes?
Thank you.
Hello @pablo.espejo,
Iridium Edge would only work when there is no GSM connectivity on the area. In this case, on normal situations device will work on its own and if the GSM signal is lost then it would work on the Satellite Backup.
Suggesting you to check on the Iridium FAQ for more information: Iridium Edge FAQ - Teltonika Telematics Wiki
Hope this helps.
Patrick
