I have been testing the use FMC650 Pro Trakcer for a couple of weeks now. I have been using the configurator fine, trying multiple different configs and features.
Now I am blocked, since the configuration is always showing errors, when trying to load data from device, or save data to device.
I hope you are doing well. Can you help check if the device that you are loading the Configuration has the same Firmware version?
Otherwise, if not, you might receive the error of being unable to load the parameters from the device. The Latest Firmware version of FMC650 can be found on this link: Firmware versions - Teltonika Telematics Wiki
