FMC650 CANbus use
Hi, I am a developer for FMC650 -based application, that is: monitoring of a little agricultura device.
The FMC650 looks like a pretty, powerful device but I have the feeling that the firmware is still a little immature. I noticed the following issues. Please note I am using “manual CAN commands” due to the specifications of the vehicle monitored, which is based on CANopen and not on J1939.
  1. if I program certain “Manual CAN commands”, they are wiped after system reboot
  2. CAN commands cannot be configured by SMS
  3. using 500kbps speed, signal acquisition is unstable - after 10, 15 minutes CAN data is suspended. I suspect it is due to some “sleep” options, even if I disabled all of these functions
  4. if I ask CAN message content through SMS, i receive the DECIMAL content, which is unusable (HEX like in the transmitted codec8 data would be much better).
TFT-100 on the same vehicle works perfectly.
Can you please check? I have the feeling that these issues can only be solved by Teltonika firmware developers
Thanks!
Hi @lorenzoemob3
Good day. Thank you for informing us about this issue. To investigate the case, please contact your sales manager or create an HD ticket.
Kindly include the following information.
  1. IMEI.
  2. Firmware version
  3. FMC650 log file ( collect logs when the issue is being recreated )
  4. Configuration file
  5. Vehicle details
If you don’t have any contact with our Sales managers, please contact them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it.
Best Regards
Maynard C
