Hi
I am using different devices on my server, with Codec 8 and Codec 8 ext.
FMB204, FMM230, FMC640 and FMC650.
It is with this last FMC650 that I have the problem that I can’t see where to set the ACK Type (TCP or AVL).
Could you help me to define this?
I am having similar problem with FMC650, I think we need to implement the ACK in our code. I have tried various approaches. But not fully successful.
Did you find a solution?
Hi Hassanor
Not, I can’t find the solution. In our server we have several FMC640 working in CODEC8 EXT without problems, but with all the FMC650 (and different FW) I find the same problem, The FMC650 does not recognize the ACK from my server.
Hi @geo1 . @hassannoor
Good day, by default the teltonika ACK is AVL, kindly try and test and let me know the results.
Please find this wiki page for more information: Help with Server FAQ - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
Maynard C
Thank you Maynar
Yes, we use AVL - ACK
With the FMB240 you can choose between ACK : tcp/IP or ACK AVL.
Our platform always uses ACK AVL. We have no problem with FMB204, FMC640 (both in Codec 8 or Codec 8 Ext).
The only problem is with FMC650
I agree with @geo1. We have implemented FMC003, FMB020, TFT100. And some more trackers, with any problems. FMC650 is a problem. I am in touch with you guys using helpdesk still no solution. In other devices we are using TCP ack. but FMC650 does not have this option. We doing ACK from server, We recevice same data again and again.
https://wiki.teltonika-gps.com/view/Teltonika_AVL_Protocols
At this point I do not know what to do and I am searching online. But solution
