FMC150 stops updating
Hi!
I have got several FMC150 devices working several weeks ago from. One of them stoped sending information some days ago. Once connected to a computer I saw that ‘GPRS Status’ was disabled. Firmware update didn’t solved the problem. Testing another SIM card didn’t resolved the problem. I had to reset device configuration and reload it again.
Which could be the problem?
I can see a ‘Transfer AGPSM file’ update some days ago, may be the date where it stopped working. Other devices has that update but they are working ok.
Regards
The ‘Transfer AGPSM file’ update that was installed around the time the device stopped working could have caused a software glitch or conflict with the configuration settings, leading to the issue. Resetting the configuration would have cleared any conflicting settings.
Edited by slope game 1 day ago
Hello @csifalmeria
Device memory might get full as that could be the problem that device stopped sending data.
Please connect device and format external usage
You can format from below command:
  1. sdformat
  2. deleterecords
Furthermore, reset the configuration of the device and add the APN.
Then, try to check if it works or not.
In case it doesn’t work, the device might have an issue with the modem.
We need to check the log in order to investigate further on the issue.
Please create HD ticket and share with us the data logs along with configuration file of device ,
If you don’t have any contacts with our Sale managers, please contact with them on our official website https://teltonika-iot-group.com/ and click on “Contact Us” button. When you will click, please fill the form and submit it.
Regards
Maryam
The memory was not full when it stopped working. The device was firmware updated an configuration resetted so I don’t know if any logs still alive. Where can I find those logs?
Thank you for the detailed response, Maryam! I’m a bit confused about the sdformat and deleterecords commands—will running these commands delete any critical data or configurations I need to back up beforehand? Also, where exactly can I retrieve the device logs for the HD ticket? Thanks in advance!
Hi @csifalmeria , @mhill
Please check this wiki page for more info: How to capture direct log from FM device? - Wiki Knowledge Base | Teltonika GPS
Best Regard
Maynard C
