FMC150 + ECAN02: Some CAN Parameters Are Not Reporting Data. Is a Vehicle-Specific OEM File Required?
Hello, Teltonika community.
I am testing CAN data acquisition from a vehicle using a Teltonika FMC150 tracker connected to an ECAN02 CAN adapter. The connection allows me to obtain data from some vehicle parameters; however, other parameters do not report any data in Teltonika Configurator, specifically in the CAN I/O Values section.
The parameters I still need to validate are:
  • Engine RPM.
  • Fuel level.
  • Fuel consumption.
  • Engine operating time.
  • Indicators in the Control Flags and Security Flags sections.
  • Odometer reading and validation.
I understand that OEM files are used to define or select how CAN data is interpreted for specific vehicle models. Therefore, I would like to confirm whether the missing readings could be related to the absence of the appropriate OEM file for the vehicle I am working with.
My questions are as follows:
  1. Is a vehicle-specific OEM file required to obtain all available parameters through the ECAN02 and FMC150, based on the vehicle’s make, model, and year?
  2. If some CAN parameters are being read correctly while others show no data, could this be caused by the missing OEM file, or could it also be related to device configuration, vehicle compatibility, or the availability of those data on the CAN bus?
  3. How can I determine whether the parameters that are not reporting data are supported by the vehicle and are actually available on its CAN network?
  4. Where can I obtain the appropriate OEM file for my vehicle, and how can I verify that it matches the exact make, model, and year?
  5. Is there a recommended troubleshooting procedure to diagnose this issue before ruling out vehicle compatibility with the ECAN02?
My goal is to identify the cause of the missing readings and determine which configuration or file is required to obtain as many of the vehicle’s available CAN parameters as possible. I would appreciate any guidance, technical documentation, or recommendations for carrying out these tests correctly.
Thank you in advance for your help.
Good day,
Thank you for raising the queries on the forum.
Here are the answers to your questions:
  1. Yes, FMC150 CAN reading capability is vehicle OEM specific. Each supported OEM file from the device is subjected to vehicle’s make, model, engine type and year.
  2. To check what are the parameters available, you need to refer to the FMX150 supported list from our wiki. From the excel list, each vehicle would have show what are the parameters supported and what are not.
  3. You may refer to our supported list to check is the parameter supported. If there are CAN data being displayed in the Teltonika Configurator Status->CAN Adapters Info or from the CAN I/O but not showing at your server, you may need to check is the CAN I/O priority being changed to “Low”, “High” or “Panic” instead of “None”. Without triggering the I/O to such priority will cause the CAN I/O to be excluded from the AVL packets. Generally, a supported CAN parameter I/O will be colored with green in the Configurator.
  4. AutoScan feature would helps you to get the appropriate OEM file for the device. It will scan through the supported vehicle’s CAN data and download the necessary OEM file from FOTA Web, provided that there’s no issue with the CAN wiring.
  5. ECAN02 is a contactless CAN data reader, you may find more information on how to install it here: ECAN02 - Teltonika Telematics Wiki
For troubleshooting, you may refer to the CAN adapter SMS/GPRS command.
Example of checking CAN lines connectivity: FMB lvcancheck - Teltonika Telematics Wiki
If the device still not showing CAN data or showing incorrectly after AutoScan, kindly ensure that the device firmware and CAN chip firmware is updated to the latest and try it again.
If issue persisted due to vehicle is not supported or you required additional support, kindly reach out to sales from Contact Us to have access to the Partner Portal.
Victor How
Good day, Victor.
Thank you for your response and for the information provided.
I have checked the supported vehicle list, but I could not find the Changan Honor 2026 van. I have also run the AutoScan function on the FMC150; however, no additional parameters have been detected or made available. I am still receiving data from only some of the vehicle’s CAN parameters.
For this reason, I would like to ask about the procedure for requesting the development or addition of a vehicle-specific OEM file for the Changan Honor 2026 so that we can evaluate the possibility of obtaining more CAN parameters through the FMC150 and ECAN02.
Is it possible to request this OEM file from Teltonika’s technical team? If so, what vehicle information or technical documentation would you need to evaluate this request?
Additionally, I would like to know whether it would be possible to speak directly with a technical support specialist via telephone call or video call to review this case and receive guidance on the tests we could perform.
Thank you very much for your time and assistance. I look forward to your recommendations regarding the next steps.
Best regards.
Good day,
Thank you for your response.
Yes, this explains a lot why the CAN parameters is not showing or only showing a few since it is not inside the supported list.
To proceed your case, kindly reach out to sales from our contact page to obtain access to the Helpdesk for requesting addition of a vehicle-specific OEM file for the Changan Honor 2026.
Cheers,
Victor How
