FMC150 CAN data
Hello, i have FMC150 FW 04.01.00 Rev 08, Configuration 13.0.0.0. Software Teltonika Configurator_1.8.21_B.4.01_R.10. Connected VCC, ground, CAN1L and CAN1H directly to car OBD2 socket pins. I uploaded correct OBD file from FOTA. GPS location is uploading correctly to traccar server. I can see power voltage in teltonika status ( means obd is powering FMC correctly)
But no CAN data present i tried it on 2 different cars, both supported BMW 5 F10 and Mitsubishi Pajero MK3. Am i doing something wrong? thank you
Good Day,
It is not always the case that the required CAN lines are located behind the OBD port for the mentioned vehicles. Due to this, CAN data may not be received if the device is connected only to the CAN lines available at the OBD connector.
Kindly use the FMx150 Autoscan procedure so that if the wiring is correct, the correct CAN OEM file is downloaded. For more details, please refer to the wiki link given below:
FMC150 AutoScan - Teltonika Telematics Wiki
For the correct FMC150 connection points and vehicle-specific schematics, kindly contact your sales manager so they can assist with creating a Partner Portal ticket. The required schematics can then be provided through the Partner Portal.
Thanks, and best regards,
Imran S.
