Fmc130 with CAN- Engine Worktime and Engine Worktime (counted) values seem reversed
Hi everyone,
We’re having an issue with one of our FMC130 devices installed with CANBUS on a John Deere harvester.
On our monitoring platform, the Engine Worktime values don’t seem to be reported correctly. We have two parameters showing:
  • Engine Worktime
  • Engine Worktime (counted)
When checking the data on Flespi, we noticed that the actual engine hour value (from CAN) appears under engine worktime counted instead of engine worktime.
Example:
  • On our platform → Engine Worktime: 2h
  • On our platform → Engine Worktime (counted): 6300h
It looks like the values are swapped.
Has anyone else experienced this issue, or can someone from Teltonika confirm if this is expected behavior or a configuration issue?
Thanks in advance for your help!
Hello @claudesg,
Kindly find below the AVL ID used for Engine Worktime and Engine Worktime (counted). Please note that the counted value were calculated since the CAN adapter were connected on the vehicle.
Patrick S.
