I have simple question:
Something is going wrong. As far as I understand my FMC130 should wakeup by motion via the build in accelerating sensor also when it is sleeping in Ultra Deep Sleep Mode.
All I can see ist the “ignition On” event (triggered by wire DIN1 yellow cable) in UDS.
No motion is shown in this mode (seen by the Traccar server logs)
When FMC130 is in DeepSleep Mode the “same” motion will trigger an event (seen by the Traccar server logs)
What parameter do I need to crosscheck?
Is it right that this should work in UltraDeepSleep Mode as well as in DeepSleep Mode?
Any hint what I can look up in my configuration? I have no idea anymore - stucked in this problem since days.
Thanks in advance for Your support
Regards RapidHarbor83
Good day,
Thank you for writing your queries in the Telematics forum.
Yes, the accelerometer would wake the device when motion is detected, regardless of what movement source was selected. This logic imply the same to DIN input. Kindly ensure that the device were updated to the latest firmware, you may find the latest firmware here:Firmware versions - Teltonika Telematics Wiki
Generally, Ultra deep sleep mode would turn OFF GPS and GSM modem and device functions are suspended for maximum battery saving. Therefore, when it is moved, it requires more time for the device to obtain “Fix” location and establish connection to your server. This may be the reason why it is not shown in your server immediately. Depending on your configuration, if the “Record Saving/ Sending” were set to “After Position Fix”. Then it would even require longer waiting time depending on the GNSS coverage area. For testing purpose, change it to “Always” and try again.
You may refer to the sleep mode function in this wiki link:FMC130 Sleep modes - Teltonika Telematics Wiki
If the device is on your test bench, one simple test you can do is to see is there any LED blinking after the movement. If LED blinking is observed, it means that device is waking up. You may connect the device to your Configurator and observed is the device being awake since Ultra Deep Sleep Mode will disconnect the device from the PC when it goes to sleep.
I hope this solve your issue.
Kindly reach out to our sales from Contact Us to obtain a Partner Portal account if the issue still persist.
Victor How
