Fmc130/fmb130 use of the buzzer and immobilizer
I installed a BUZZER on the DOUT 2 output and configured it to sound when the speed exceeds the set limit and for driver identification. However, it only works for driver identification; it sounds until the key is turned on. But when the speed exceeds the limit, the buzzer does not sound.
CAN I USE A SINGLE OUTPUT FOR BOTH FUNCTIONS?
APOYO
Good day, please change the priority of Immobilizer and overspeeding to LOW and make a test again, you have configured both scenarios as HIGH priority and the DOUT you selected is the same meaning there will be a conflict with the DOUT activation.
Best Regard
Maynard C
Can I set one to high priority and the other to low priority, and that way it would work using the same output? Or do I necessarily have to have both set to low priority?
Hi @Claudio
You can make a test to know the results, also if this didn’t work kindly try to use a different DOUT like DOUT 1 for overspeeding and DOUT 2 for Immobilizer
Best Regards
Maynard C
I need a FIRMWARE update so that the same output can be activated for different functions. As I ask you, I talk to my manager to order it because we are your customers.
Hi @Claudio
Good day, if you experience any issues or you want specific requirements kindly contact your sales manager or create an HD ticket.
Best Regards
Maynard C
Both situations didn’t work.
I want to use a single output for different functions. Does that have an additional cost if we are customers or not? And how long would that FW take with that modification?
Can you pass me the link where I should place the application, please.
Hi @Claudio
Good day, please get in touch with your sales manager. If you don’t have any contact with our Sales managers, please get in touch with them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you click, please fill out the form and submit it.
Best Regards
Maynard C
