We have a few units of FMC130 that stop sending its data once the internal memory is full. Is there a way to fix this? Or is there a config to not write the data in the internal memory? Only send it straight away to the server.
Hi @akmalaliff
What is the firmware version that you are using?
Please use the official latest firmware for our device: wiki.teltonika-gps.com/view/Firmware_versions
The device should send the data immediately to your server , please check the settings below and test. Make sure that the minimum records is set to 1 so that if there is 1 record available the device will send it straight away to your server.
Please try to use the latest firmware for FMC130 kindly download it here; https://wiki.teltonika-gps.com/view/Special:Redirect/file/FMB.Ver.03.29.00.Rev.18_and_configurator.zip
Best Regards
Maynard C
