Hi! I would like to know if it possible to connect FMC130 to two Fuel Level Sensor (TD-150 Escort). If Yes, How should should I proceed please?
Dear @Nguenga,
I hope you are doing well. If you were connecting the Fuel Level Sensor (TD-150 Escort) via Bluetooth 4.0, then you can configure up to 4 sensors.
In this case, you need to configure and set the MAC Address for the BLE Sensor 1 and 2 so that you can receive the records from these sensors. For more information about BLE 4.0, you may refer to this link: FMC130 Bluetooth® 4.0 settings - Teltonika Telematics Wiki
Similar Configuration of the device can be referred on this link, however instead of setting Technoton on the Preset you need to select Escort sensor. Technoton DUT-E S7 Fuel Level Sensor - Teltonika Telematics Wiki
I hope this helps.
Patrick
@Patrick_Sangalang Thank you very much for your help.
