FMC130 Configuration with Geofences
I am using a FMC130. I set up mulitple Geofences and gave each of them the “High Priority” and set them to both, enter and leave the fence. I only want the Device to record and send data when entering and leaving the Geofences together with some additional data from DI1+2 (which I set the Priority to Low).
So to avoid any additional records, I set all the data aquisition Values to the minimum (mostly 0). However when setting the “Send Period” Parmeters to 0, no data is sent at all.
How can I get the desired behavior?
Hi Lobin,
Good day, If you set the parameters to 0 for data acquisition settings meaning you are disabling this feature, that is why you are not receiving records from your server.
Please find the details through this wiki link: FMC130 Data acquisition settings - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
Best Regards
Maynard C
Hi Maynard,
thank you for reply. There is a little confusion here: If I set any I/O Parameters Priority to “High”, shouldn’t then the data be sent independently from the Data acquisition settings? (as described in FMC130 I/O settings - Wiki Knowledge Base | Teltonika GPS )
best regards,
Wolfgang
Hi Lobin,
High Priority will send records immediately to your server together with other parameters which is enabled.
Note: It will only work if you set an operand like On change, On Change, On entrace etc. except from monitoring, monitoring will work same as low priority even the priority is set to High.
Best Regards
Maynard C
This topic was automatically closed after 12 days. New replies are no longer allowed.
