Hi , have a good day.
Im working with FMC125 testing the RS232 Mode. I got communication with the server using TCP/UDP Ascci in both ways.
Using TCP/UDP Ascii Buffered have not get any result . How should be the message to be sent ? Im using x-ctu program to test the serial port.
At the end what Im looking for is to get the latitude and longitude added to the serial message.
Hi , thanks a lot for your answer .
I resolve the problem updating the firmaware and Im receiving serial data and sending serial data to the server using TCP/UDP ascci and others similar modes,
Now the issue is using the delimeter mode , I can send serial info to the server and getting the coords and time , but when i try to send info from server to the serial gps port using #DO DAT, I cant see the info in the serial port but the server receives the acknowledge message : #NOT OK.
So , Im not sure what else I have to do to view the info in the serial port like the other tcp/udp modes.
Good day, if I understand it correctly, you want to send the GPRS command from your server using delimiter mode, in this case, the device will not receive it because delimiter mode only reads the data from the RS232 port with AVL ID109.
