FMC125 con RFID RS232
Hello everyone
I would like to know how to configure an FMC125 in the RS232/RS485 section to read RFID cards. I base it on what I see in the Wiki but it does not generate a reading.
I appreciate your comments.
Hi @Yonathan,
please ask your questions in English. The answers will
be in English anyway. Google Translate will help you.
Timelapse Admin
Good day, please check our wiki page: FMB125 RS-232 and RS-485 - Wiki Knowledge Base | Teltonika GPS (teltonika-gps.com)
If you are using RFID HID anre RFID MF7 then it should work, please double check the connection/wiring also the corrrect baudrate.
If you are using different RFID protocol try to use the TCP Binary mode.
Here is the wiring schemes: Wiring-scheme-FMB125.jpg (2260×1394) (teltonika-gps.com)
Best Regards
Maynard C
